AutoCAD MEP General Discussion
Active Member
0 Kudos
Post 1 of 3
MEP 2013 - Conduits are Square??
296 Views, 2 Replies
11-26-2012 09:14 AM
I'm running MEP 2013 and when i send out my electrical conduit files to people who are using 2012 and lower, all the conduits come in square.
I've tried saving the files down to 2004 and it still does nothing for users that are using 2012 or lower.
Any ideas?
Distinguished Contributor
3 Kudos
Post 2 of 3
Re: MEP 2013 - Conduits are Square??
11-26-2012 10:45 AM in reply to: adamheon
Good luck with that! We are still using 2012 until all our extended team decides together to move to 2013, mainly because of the compatibility issue you present. The objects in 2013 are 2013, and there is no way to save the "object" to a lower version. There is a way to see a "dumby" version of 3D objects without the squares, if that works for you. Put your 2013 model into Isometric view, then Export to the 2010 format. The objects will be 3D round but not smart.
108 Kudos
Post 3 of 3
12-01-2012 10:46 AM in reply to: jcleghorn
You can also use the CONVERTTO3DSOLID command to convert all of your objects to 3D solids and save down to a version prior to 2013.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
