I'm using Content Builder to create a custom sink, but when it gets to the part where you add connectors, I select the supply's and waste connection points, but for some reason it doesn't put it in the same place I click.
Everything is offset very far to the right side. The placement of the supply's and waste connections look correct in relation to each other, but they just aren't attaching to the part correctly. Anyone else having this problem or know the solution?
Tuan
I have also had issues with this if your insertion point on your block is not at 0,0,0. It doesnt happen all the time but might you might try it. It could have something to do with the world ucs issue. At the time i never noticed the ucs.
