Does anyone else feel that 2010 has taken a few steps in the backward direction as far as productivity is concerned? Below is a list of a few of the things I have found that have dropped the speed at which I can produce by a large amount:
- Osnaps used to work that when you hit F3 you would turn on your regular autocad osnaps and turn off the MEP snaps and vice versa. Now they are all linked to the F3 key so they are either all on or all off. This causes a huge headache when you are trying to snap to ductwork or piping.
- The label curve modify has been REMOVED from the right click menu. HUGE mistake! As I see it, the only way to change the label curve style from one to the other is through the properties tool bar.
- I do like the layer list on a tool bar but for some reason it seems to hang up when it flys out and goes back.
- And one final one....when ctrl-tabbing from drawing to drawing, it takes WAY longer than it used to for me.
Now these last 2 could be specific to my system but I've got a pretty stout Xi computer and I would like to think that there wouldn't be speed or graphic issues with it.
I guess that's the end of my rant, if anyone has any feedback on this it, post away.
