Anyone kindly upload/share (through dropbox or email at muhammad.shayan17@gmail.com) the mechanical-defualt template (rte file) of Revit MEP 2015. I'll be greatly indebted!
This is the AutoCAD MEP forum. You might want to try the REVIT MEP forum to get better results as that is the program that you are asking about.
This needs to be in the Revit forum, but the templates for Revit are located in this folder on your computer:
C:\ProgramData\Autodesk\RVT 2015\Templates\US Imperial (or the version you installed).
thanks - db
David A. Butts
Engineering Technology Manager - Gannett Fleming
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
If you can't find the templates, you may be having other issues - what version of Revit do you have installed (part of suite, or standalone, student or commercial version, etc.), and did you have administrative rights to the computer? did you do a typical installation or custom?
If you didn't get the templates, you probably will have issues with the library as well, and getting the template won't help much.
thanks - db
David A. Butts
Using Revit MEP 2015, Standalone! Got the libraries; they are working fine! Am designing a duct system; but whenever i try starting from a new template the error about no default fittings show up even though i did put them in the routing preferences!
But when working in a template file( downloaded one of the Revit 2012 version from internet) the ducting works fine.
