AutoCAD MEP General Discussion
New Member
cadd1030
Message 1 of 2 (139 Views)
Mechanical Pipe Risers
139 Views, 1 Replies
07-18-2003 12:27 AM
When I draw a pipe and end it with a turn up as a riser the single line drawing shows it as a turn down symbol if I remove any straight pipe connected to the elbow that turns up it shows as a riser symbol. Is there a fix to this besides erasing any vertical pipes on my risers?
Distinguished Contributor
jmcfaddn
Message 2 of 2 (139 Views)
Re: Mechanical Pipe Risers
07-18-2003 03:56 AM in reply to: cadd1030
Have you tried to change the flow direction? Select the riser pipe, right click mouse, select set flow, then select reverse. See if that changes your riser symbol.
Let me know.
Jmcfaddn
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
