Scott -
Placeholders are essentially body-less duct and pipe fittings. I think this
will give one line behavior that may get you a step closer to 3D schematic.
To use Placeholders, do the following:
1. Open Pipe Preferences and make sure you have default parts set for the
placeholders.
2. Open PipeAdd
3. Set the Thickness Gauge to Undefined Gauge.
Start drawing pipe - it will be with schematic fittings that have no size
instead of a full bodied pipe. Note that placeholders are fully 3D.
Placeholder elbows, tees, crosses are there, but as Jason notes, however,
there is a lack of placeholder content specific to plumbing fittings.
3D plumbing fittings for use with the PipeAdd and PipeFittingAdd commands
are a priority for us.
Let us know how you make out.
I hope this helps!
"jason martin [Autodesk]" wrote in message
news:5CD490B38844C1FA51DB0FD0B2D6EF0C@in.WebX.maYIadrTaRb...
> Hi Scott -
> There are some people using the piping package for plumbing layouts, but
> there is currently very limited content for this type of layout. Items
like
> sanitary fittings don't currently exist in the piping catalog, so there
may
> be some "challenges" in laying out waste systems that are completely
modeled
> without some significant content work.
> The concept behind placeholders was that they could be used for initial
> layout, when the designer didn't know all of the "required" information
> about the system to select the exact type of content that was to be used,
> and then easily modify the placeholder content with specific content as
the
> design progressed.
> hth
> jason
> "scott" wrote in message
> news:1C2501ECFB7B0E23C2CA67B71E3EFE1B@in.WebX.maYIadrTaRb...
> > Has anyone used the mechanical pipe add command to be used with plumbing
> > layouts. I was informed by a rep from autodesk that I should try to use
> this
> > command with my plumbing layouts and to get that 3d effect. Also the rep
> > told me about using the place holders. Can someone explaine to me more
in
> > detail what place holders do or can do? I would greatly appreciate any
> > assistance or comments.
> > Scott
> > RGD
