AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
locked layer fading
1 REPLY 1
yami_akai
3114 Views, 1 Reply
locked layer fading
I have xref's as my backgrounds and they are on a locked layer. The layer is faded because of the layer being locked. How do I get the layer to print faded like that? It used to do it in 2011, but when I upgraded to 2012 it stopped doing it.
1 REPLY 1
jcampbell924
in reply to: yami_akai
The layerfade and xreffade controls are just a visual on-screen fade and do not affect plotting.  The only way I know to affect plotting like this besides applying a pen table or changing the layer color of the xref layer is to use the layer transparency options.  Starting with 2011 we were able to add a layer transparancey in the layer manager for selected xref's.  I use a filter to select the xref layers and then apply like a 70% transparency level. When plotting, make sure you check the "Plot transparency option"  This should get the affect you are looking for.
”Boost
