AutoCAD MEP General Discussion
*Bernhardt, Kyle
Message 1 of 4 (85 Views)
Labeling Pipes in 1-line view
85 Views, 3 Replies
08-11-2003 04:46 AM
I've noticed that when a label is placed on a pipe object, and the display
configuration is set to 1-line, that the pipe line does not trim itself
around the label. This is different than in schematic lines where the pipe
line is trimmed around the label. Is anybody aware of a way to get the line
to trim? If there is no way, the Autodesk...at that to the list of fixes
that need to be done to the program.
Kyle Bernhardt
Mechanical Engineer
Dagher Engineering
29 Broadway
New York, NY 10006
*[Autodesk], jason martin
Message 2 of 4 (85 Views)
Re: Labeling Pipes in 1-line view
08-11-2003 05:07 AM in reply to: *Bernhardt, Kyle
Yes, labels will mask the single line display of a pipe. Please make sure
that you have the "Mask Display of Curve" turned on in the label style.
hth
jason
"Kyle Bernhardt" wrote in message
news:474B04651A93D0C500968B5CBE3311ED@in.WebX.maYIadrTaRb...
pipe
line
> Kyle Bernhardt
> Mechanical Engineer
> Dagher Engineering
> 29 Broadway
> New York, NY 10006
*Bernhardt, Kyle
Message 3 of 4 (85 Views)
Re:
08-11-2003 06:19 AM in reply to: *Bernhardt, Kyle
I have that set already and I still see the line. It is strange though,
because I cannot select the line behind the text, yet it is still displayed.
I can see that the line appears to be trimmed when I select the pipe,
because the dotted line representing the selected pipe stops being dotted
around where the line would be trimmed, but there still is that line there.
Is there a "Display Masked Lines" setting that I need to change? For your
info, I'm looking at the "ABS Floor - 1 Line" configuration right now.
Kyle Bernhardt
Mechanical Engineer
Dagher Engineering
29 Broadway
New York, NY 10006
Message 4 of 4 (85 Views)
Re:
08-11-2003 01:28 PM in reply to: *Bernhardt, Kyle
Hi Kyle -
It sounds like you have more than one display of the piping drawing itself
right now. Check display manager and make sure for the current config, that
there is only 1 display rep on for piping. If that doesn't work, could you
post or email the drawing? I'll take a look.
jason
news:AD355F78A8C1D9998504B68FA156B883@in.WebX.maYIadrTaRb...
displayed.
there.
> Kyle Bernhardt
> Mechanical Engineer
> Dagher Engineering
> 29 Broadway
> New York, NY 10006
Post to the Community
New Post
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
