AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Labeling Data Outlets
2 REPLIES 2
optimus_said_what
486 Views, 2 Replies
Is there a way to automatically label data outlets with a custom name & tied to a data base so that if I get done labeling a floor if I happen to miss one I can just add a port or two and the devices that I did already label would automatically update?  I would also like to be able to export the labels to an easy to read Excel spreadsheet, if possible.
2 REPLIES 2
apparently not possible??
To make sure I understand, you have a scenario where you have devices connected (circuited) and numbered, 1 through 10.
Then, you insert a device, perhaps you want it at position 5… you want the previously circuited elements 5-10 to become 6-11.
This would be possible with the Electrical Project Database APIs using the .NET programming interface.
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
Autodesk, Inc.
”Boost
