Hi Clint -
Unless you are running with duct length on this is the default behavior. You
get 1 label "per segment". If you have duct length on (say, creating 5'
segments) then you will still get one label per segment, you just have a
segment every 5'.
Are you seeing different behavior?
jason martin
"Clint Schwartz" wrote in message
news:749E2CD76EF192890B7C8EA4860C9E8D@in.WebX.maYIadrTaRb...
> A duct joint would be a straight piece of duct. Since the software
> automatically merges straight pieces of duct between fittings, it wouldn't
> seem too hard to tell it to just do one label automatically for every
> straight piece of duct. It seems to put a label on about every 5' or so
> when it's set to automatic as you draw duct and that is just too often and
> makes the drawing way too cluttered.
> "jason martin [Autodesk]" wrote in message
> news:26AF50E01C1AD809C848684A92D207B0@in.WebX.maYIadrTaRb...
> > Hi Clint -
> > Probably not, but could you tell me what you mean by a duct joint?
(sorry,
> > I'm slow;-)
> > Do you have duct length turned on?
> > jason
> > news:f156db8.-1@WebX.maYIadrTaRb...
> > > Is there a way to set the labels so that only one node is created for
> each
> > > duct joint?
