AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Label of Air Terminal Information
8 REPLIES 8
Message 1 of 9
marco.defina
1246 Views, 8 Replies
i tried to set the indication of air terminal to see the quantity of air flow, but don't work...
I started with this command:
Then i have this mask and i will see on the label the information highlighted with red arrow:
But everytime the result is this.
Someone can help me to set right?
Attached the file.
Thank you.
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
8 REPLIES 8
Message 2 of 9
Keith.Brown
in reply to: marco.defina
Your Air Terminal Tag is incorrect.  It is trying to read the air flow from a property set definiton named Portata which doesnt exist.  It should instead read the FlowRate property set definition.
You can verify this yourself by opening up the Aecb_Mechanical_Air_Terminal_Device_Tag block and view the tag.  You can change the name of the property set here by changing Portata to FlowRate.
p.s.  I did this myself in the drawing you provided and it worked fine.
Message 3 of 9
marco.defina
in reply to: Keith.Brown
Can you capture the step with a video or send me the drawing?
Message 4 of 9
marco.defina
It's empty Smiley Mad
i can't set nothing...
Message 5 of 9
Keith.Brown
Here you go.
Message 6 of 9
marco.defina
Thank you, it works!
But i can't open with double click the edit attribute, i need everytime to write _ddedit...Smiley Frustrated
The name of the program you used to capture the video?
Message 7 of 9
marco.defina
It's possible to have the Label with only 2 position of information, the third with the dimension of dutc i don't need.
Message 8 of 9
Keith.Brown
You can approach this two ways.  You can edit the block again and remove the part of the label that you do not need or you can create a new label from scratch.  Below is a link to a video of a webinar series that shows how to create a tags and labels.  That particular video is for a pipe tag and label.
http://www.youtube.com/watch?v=pXiZkGJz8DM&list=PLudbyTOOSbuYS9kVYB9rmlquTYKOoyUAd
The duct video of the series should be available next week.
Here is a link to a blog series on how to create a duct tag.  You should be able to modify the directions to work with the air terminal.
p.s.  I used camtasia to create the video above.  I produced it as a gif so it could be easily shown inside the post.
Message 9 of 9
marco.defina
it's a way to have in the Label the name of the Layer?
”Boost
