I cant seem to fid a way for the label curves to display in the same orientation
It seems to depend on the way the pipe was drawn
I tried to reverse the flow with no luck
I dont want to have to redraw the pipe especially where I have a lot of takeoffs
I can make a work around adding a pipe section, but there must be a better way
screenshot attached
Cheers
Pete
Can you share a small simple drawing? It is difficult for me to determine what is going on from an image alone.
I agree with Keith, a sample drawing would be very helpful. I can't reproduce this issue. Here is a video showing pipe labels. They come in Right Reading regardless of how the pipes are drawn. You can adjust the style to have all labels be forced to horizontal but I'm not sure how the labels would flip. A sample drawing would be very helpful in figuring out this issue.
BTW - if you want the try the utility that I used to create the video, you can download it for free here: www.autodesk.com/screencast
