I'm just getting started with MEP 2011, I work in the HVAC Trade (Duct). I have found myself needing to get up to speed quickly! I would appreciate any suggestions on how best to get started with tutorials, videos, etc. I have some experience with AutoCAD and a much older version of MEP. This is totally different! A push in the right direction would be appreciated.
Thanks, atinbender
As you said Tutorials, it will teach you how to use the tools to get the job done. Anythings else you have to explore.
Apart from the numerous Youtube videos out there, I find Paul F Aubins books very useful!
Take time to set up your template file and standards properly from start, it will speed up the learning process a lot!
/Patrik
You could also check the below links which could give you a first-hand push to AutoCAD MEP.
User's Guide
http://images.autodesk.com/adsk/files/autocad_mep_user_guide_english.pdf
Skill Builders
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=12785549&linkID=9240935
Tutorials
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=9493064&linkID=9240935
There are also a lot of videos posted on YouTube which you could check.
http://www.youtube.com/results?search_query=autocad+mep+2011+tutorial&oq=AutoCAD+MEP+&aq=2&aqi=g10&a...
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
