I would like a tool (like Qselect) that allows for selection of devices on property data values. Is it possible?
Solved by Keith.Brown. Go to Solution.
There is no out of the box function that will provide this ability but there is an app on the app store that will do exactly what you want. You can download it for free from here: http://apps.exchange.autodesk.com/MEP/en/Detail/Index?id=appstore.exchange.autodesk.com%3acoinsprope...
the app is Coins Property Select. I am sure if you search on that term you will find it.
or try
Hello, the App isn't in the Autodesk App Store now, I don't know why. I have wrote Coins Global but my english is so poor so I'll wait till they answer... Was the App free? If not, how much did it cost? If it was free, someone can share with me via Dropbox please? Thank you!
Our COINS Property Select application is free. It was taken down from the app store a couple of weeks ago because of an issue with the AutoCAD Architecture/MEP 2015 release. However, it has been resubmitted and should be back up in the next week or two. In the mean time, send an email to support dot us at coins-global.com and I'll be happy to get you the install.
Goyo - I've emailed you with a direct link.
Jon Smith
COINS
