AutoCAD MEP General Discussion
Keith.Brown
Message 1 of 3 (585 Views)
IfcPersonAndOrganization AutoCad MEP 2013
585 Views, 2 Replies
10-12-2012 04:26 PM
When I use the IFCRESOURCEASSIGN command and create IfcPerson's, IfcOrganization's, and IfcPersonAndOrganization's they do not show up in the IFC file.  If i create an OwnerHistory on the Assignment tab then the IfcPersonAndOrganization that was assigned to the owner will show up but I can only create 1 OwnerHistory.  What about the rest of the IfcPersonAndOrganizations that were created?  It seems that only items added in the Assignment tab show up in the ifc file which doesnt seem correct.
Has anyone else experimented with this and found it behaves differently?  Is this working as intended or is it a bug?
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Use the AECIFCEXPORT command.  An IFC export dialog pops up.  This is new to 2013. In that dialog, you can now click the "Resource and Assignment" button.  It pulls up a new dialog to specify persons, addresses, organizations and much more.
Hope this helps,
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Product Support
Joshua.Benoist
Message 2 of 3 (542 Views)
Re: IfcPersonAndOrganization AutoCad MEP 2013
10-17-2012 11:21 AM in reply to: Keith.Brown
Hope this helps,
Joshua
Joshua Benoist, PE
Senior Support Specialist
Product Support
Keith.Brown
Message 3 of 3 (531 Views)
10-18-2012 12:51 PM in reply to: Keith.Brown
Joshua,
The Resource and Assignment button starts the same dialog as the ifcresourceassign command.  I did figure out that by using the IfcActor on the assignment tab that I could insert as many IfcPersonAndOrganizations into the export as I needed.  Thanks for your response.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
