AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
IfcPersonAndOrganization AutoCad MEP 2013
2 REPLIES 2
Keith.Brown
868 Views, 2 Replies
When I use the IFCRESOURCEASSIGN command and create IfcPerson's, IfcOrganization's, and IfcPersonAndOrganization's they do not show up in the IFC file.  If i create an OwnerHistory on the Assignment tab then the IfcPersonAndOrganization that was assigned to the owner will show up but I can only create 1 OwnerHistory.  What about the rest of the IfcPersonAndOrganizations that were created?  It seems that only items added in the Assignment tab show up in the ifc file which doesnt seem correct.
Has anyone else experimented with this and found it behaves differently?  Is this working as intended or is it a bug?
2 REPLIES 2
Use the AECIFCEXPORT command.  An IFC export dialog pops up.  This is new to 2013. In that dialog, you can now click the "Resource and Assignment" button.  It pulls up a new dialog to specify persons, addresses, organizations and much more.
Hope this helps,
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Keith.Brown
in reply to: Keith.Brown
Joshua,
The Resource and Assignment button starts the same dialog as the ifcresourceassign command.  I did figure out that by using the IfcActor on the assignment tab that I could insert as many IfcPersonAndOrganizations into the export as I needed.  Thanks for your response.
”Boost
