AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
i-drop ContentBrowser ToolPalette Groups into AutoCAD MEP 2013
3 REPLIES 3
mdhutchinson
937 Views, 3 Replies
Is anyone having issues with i-drop tool palette groups into AutoCAD MEP 2013?
Mine won't even drag n drop out of the box palettes.
see http://forums.augi.com/showthread.php?140670-Content-Browser-i-drop-not-working
Just wondering how many others?
I also wonder if this is not an issue that adesk didn't catch with how the vertical product now get loaded? My AutoCAD MEP installed as a sub folder into Acad 2013... at C:\Program Files\Autodesk\AutoCAD 2013\MEP
3 REPLIES 3
Mike,
In the support case, you mentioned this issue was resolved by recreating the tools from scratch in 2013.  I noticed this forum post pre-dates our support case.  Don't know why it was not working the first round.  Should we mark this forum post as solved?  You want to hold off and see if any others have this issue?
Joshua
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
The issue is not solved... it just started working on my machine without apparrent explanation as to why.
I would like to leave this open... and see if others are also having the issue.
in reply to: mdhutchinson
We are currently having this same issue in ACAD 2013. I cannot drag and drop items from the content browser into my workspace using the i-drop tool. A work around i have been using is to use the i-drop tool, move the object onto a palette, and then dragging from the palette to my work space.
Not the best use of our library or the tool.
I have reinstalled the i-drop program and this has not helped.
Funny thing is when i first installed 2013 it wokred fine, but got steadily worse until it stopped working.
Any other suggestions?
”Boost
