AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
How to stop this loading base in 2008 MEP
10 REPLIES 10
Message 1 of 11
c317tkp
3265 Views, 10 Replies
How to stop this loading base :
Loading AEC Base...
Loading AEC Base Extended...
Loading AEC Base UI...
Loading AEC Project Base...
Loading AEC Base GUI...
Loading AEC Layer Manager...
Loading AEC Schedule Data...
Loading AEC Utilities...
Loading AEC Schedule Data UI...
Loading AEC Schedule...
Loading AEC Schedule UI...
Loading AEC Architectural Base...
Loading AEC Structural Base...
Loading AEC Structural UI...
Loading AEC Publish UI...
Loading AEC Project UI...
Loading AEC Project Palette...
Loading AEC Area Base...
Loading AEC Architectural UI...
Loading AEC Annotations UI...
Loading AEC Design Center UI...
Loading AEC Dimensions Base...
Loading AecAreaCalculation50...
Loading AEC Dimensions UI...
Loading AEC Object Explode...
Loading AEC Recipe Base...
No default component database set.
No default keynote database set.
Loading AEC Detail UI...
Loading AEC Detail Extended UI...
Loading AEC Detail Base...
Loading MEP Base...
Loading MEP HVAC Base...
Loading MEP Pipe Base...
Loading MEP Electrical Base...
Loading MEP Part Services...
Loading MEP COLE Base...
Loading MEP Part Factory...
Loading MEP Plumbing Base...
Loading MEP Tools...
Loading MEP Base UI...
Loading MEP Base GUI...
Loading MEP Content Builder...
Loading MEP HVAC...
Loading MEP Piping...
Loading MEP Electrical...
Loading MEP Plumbing...
Command: LAYER
pls help
10 REPLIES 10
Message 2 of 11
in reply to: c317tkp
If you dont want all that stuff you should use plain AutoCAD.
Message 3 of 11
Some of us got MEP and want to run it as plain AutoCAD. I for one am running using the acad.cui as the main. I do not have the abs cui loaded at all.
I have run into some bugs with the third party software, which they say is from the MEP loading as the description above details.
Hopefully someone has a better answer for how to prevent the other items from loading?
Message 4 of 11
There is an option to load a plain AutoCAD profile on install.
Message 5 of 11
Yup, I used that. That sets your main cui to the acad.cui. However, sometimes the extra bases will still load.
Message 6 of 11
c317tkp
Yes i did use plain AutoCAD and use acad profile. This happen when I click on Layer manager icon or Tool Template, then it start loading?
pls refer attached, I using 2008 MEP, but i want to use plain acad. when start acad, it should be acad 2008 MEP or acad 2008.
Message 7 of 11
I figured out a little more. In order to use the vanilla profile, any of the drawings and templates you use must not have ever had the bases loaded into them....otherwise they will load the bases. I pulled out an old templete and use that in addition to the profile thing. I'd like to find a way to purge the bases and then all my problems will be solved.
Message 8 of 11
All righty...figured something else out. It's the demand load options (see attachment). You need to have "DEMANDLOAD" set to 0 in order to not have the modules load. I set this in a startup routine so that we won't have to worry about that.
You could play with the other options for loading and they should work as well.
Message 9 of 11
Pardon me, it should be set where DEMANDLOAD = 2. That's for command invoke. AutoCAD functionality will be lost if it is 0. For example, the command BATTMAN won't work with demandload = 0.
Message 10 of 11
c317tkp
yes, it work, thank you vary much.
Message 11 of 11
I found a better and more permanent fix. In the registry, if you select the profile name, some keys show up. Your profile must have a DWORD called IsPureAcadProfile and set to 1. This allows use of only AutoCAD functions.
”Boost
