AutoCAD MEP General Discussion
Distinguished Contributor
jmcfaddn
Message 1 of 4 (557 Views)
How to make a 3d Surface/Mesh?
557 Views, 3 Replies
06-30-2003 12:31 AM
I see the solids menu, but do not see where to make a 3d surface or Mesh as described in the ACAD help file?
*Andrew
Message 2 of 4 (557 Views)
Re: How to make a 3d Surface/Mesh?
06-30-2003 01:07 AM in reply to: jmcfaddn
You will need to load the standard acad menu.
Or copy that part of the acad menu into your BS menu.  Or you can type in
the commands.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
jmcfaddn
Message 3 of 4 (557 Views)
Re:
06-30-2003 02:46 AM in reply to: jmcfaddn
?? you'd think there would some menus in Bldg Sys. since we are required to build Mvparts. If I load the ACAD menu, which I've done by mistake already, I lose all of my previous menu settings. Is there a way to draw a solid then explode it to surfaces?
*[Autodesk], Bo Noren
Message 4 of 4 (557 Views)
Re:
07-01-2003 12:03 AM in reply to: jmcfaddn
It is possible to switch to AutoCAD menus by
selecting Window->Pulldowns->AutoCAD Menus. To switch back select
Building Systems->Restore Building Systems Menus. As Jody points out you
will lose your menu settings (toolbar positions e t c) when switching. If
that is a problem I would suggest using two different profiles; one for
AutoCAD menus and one for Building Systems menus.
/Bosse
it to surfaces?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
