AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
How to make a 3d Surface/Mesh?
3 REPLIES 3
808 Views, 3 Replies
I see the solids menu, but do not see where to make a 3d surface or Mesh as described in the ACAD help file?
3 REPLIES 3
You will need to load the standard acad menu.
Or copy that part of the acad menu into your BS menu.  Or you can type in
the commands.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
?? you'd think there would some menus in Bldg Sys. since we are required to build Mvparts. If I load the ACAD menu, which I've done by mistake already, I lose all of my previous menu settings. Is there a way to draw a solid then explode it to surfaces?
It is possible to switch to AutoCAD menus by
selecting Window->Pulldowns->AutoCAD Menus. To switch back select
Building Systems->Restore Building Systems Menus. As Jody points out you
will lose your menu settings (toolbar positions e t c) when switching. If
that is a problem I would suggest using two different profiles; one for
AutoCAD menus and one for Building Systems menus.
/Bosse
it to surfaces?
”Boost
