AutoCAD MEP General Discussion
Valued Contributor
0 Kudos
Post 1 of 2
how to install a valve
293 Views, 1 Replies
03-20-2013 07:44 AM
I am drwg with grooved pipe, and I want to install a vic-300 valve, so I go into equipment and I find valves, but all I see is flanged butterfly valves, how do I go about changing a valve or where would I find a vic valve to install?
thanks
108 Kudos
Post 2 of 2
Re: how to install a valve
03-20-2013 08:37 AM in reply to: mjmpe
Mjmpe,
There are certainly many other valves besides a flanged butterfly available in Autocad MEP.  There are at least over 100 different types of valves available in the out of the box setup and that is a conservative guess.  As you said there are flanged valves available and you can use a grooved flanged adapeter to connect it to your grooved pipe system.  You will not find any valves that are exactly what you want.  Autodesk does not create manufacturer specific valves.  If you want a true grooved valve then you will need to roll up your shirt sleeves and create one.  I have posted a link to the Autodesk University Class by Joshua Benoist in several of your posts.  That class and the accompanying hand out gives excellent instructions on how to create custom content.
If you are using Autocad MEP to create fabrication drawings and based on previous posts it sounds like you are then I would recommend looking at the EastCoast Cad/Cam plugin.  This plugin for Autocad MEP offers 10's of thousands of real world manufacturer specific piping parts for you to use in your fabrication models.  It also offers fabrication spool automation to assist with your spooling processes.  A simple google search will turn up the information that you are looking for.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
