How can I choose to automatically place eccentric reducers when i'm designing my pipe network?
Solved by Pothman. Go to Solution.
Drawing eccentric pipe is actually pretty simple. Assuming that you have an eccentric reducer defined in your routing preference, you can simply change the Justification of the pipe to something other than Center - for example if you want the right edge straight, then set it to Center Right. If you want the bottom flat, then set it to Bottom Center. Just remember to set it back when you are done because this setting will stay that way after you finish your run.
