AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
How to have eccentric reducers automatically placed through Auto-Layout?
2 REPLIES 2
ruipfbarreiros
861 Views, 2 Replies
How can I choose to automatically place eccentric reducers when i'm designing my pipe network?
Using Building Design Suite 2019
2 REPLIES 2
Pothman
in reply to: ruipfbarreiros
Drawing eccentric pipe is actually pretty simple. Assuming that you have an eccentric reducer defined in your routing preference, you can simply change the Justification of the pipe to something other than Center - for example if you want the right edge straight, then set it to Center Right. If you want the bottom flat, then set it to Bottom Center. Just remember to set it back when you are done because this setting will stay that way after you finish your run.
Dave Pothier
ruipfbarreiros
in reply to: Pothman
That's it! Thanks a lot! Really helpful!
”Boost
