I have been trying to overwrite the default layer key styles to my company standard key styles or layers, rather.
I was able to overwrite the Cable Tray and Fitting key styles to my company standards, but I haven't been able to overwrite the conduit key styles to mine. It appears to be on the wrong layer, like a wire layer.
How can I overwrite all the default power conduit layers to my company standard layers?
Thank you,
TTW
Solved by lesdre. Go to Solution.
How does one reset the layer key? Do you mean modifying the layer keys?
TTW
Go to Style Manger, Electrical System Definitions, select the item that you want to change and then go to the design rules tab there you will see Layer Key with a drop down select which layer you want it to represent.
