"jmcfaddn" <Is
href="mailto:jody.mcfadden@alcatel.com">jody.mcfadden@alcatel.com>
wrote in message
href="news:f1699b1.-1@WebX.maYIadrTaRb">news:f1699b1.-1@WebX.maYIadrTaRb...
there a tutorial on how to modify/create Sidewall grilles. If you look at an
existing one to modify, it's made up of 40 different parts, very complicated.
Trying to stretch or modify the existing grille elements turns out to be a
very difficult task. Has anyone modified one
successfully?
"Hakan Wikemar [Autodesk]" <
href="mailto:hakan.wikemar@autodesk.com">hakan.wikemar@autodesk.com>
skrev i meddelandet
href="news:9F259AF0752A83AC30BF6726708641D5@in.WebX.maYIadrTaRb">news:9F259AF0752A83AC30BF6726708......
I think I have managed to create blocks
that are equivalent to a 1x1 Sidewall grill (inserted a 10*6 grill with
different scales in x y and z), try and use this one in your content drawing
(just copy the blocks I placed in 0,0 to your dwg) and then the
procedure to create more grills should be as follows:
1. Insert the model block - with the desired
mesurements in the scale option (for a 13x5 grill scale x=13 Y=1
Z=5)
2. Explode the model block
face=Arial size=2>and move the horizontal grill 1" from the bottom and
array 4 copies with 1" dist uppwards, do the same thing with the verical
one but with 0.75 dist and additional times.
3. block the model block and name it
"13x5.....model"
4. The other blocks should only be to insert
scaled as previously and blocked again.
Remember to use the same insertionpoint as
previously, to be sure draw a line form the insertionpoint or something before
exploding the blocks.
I'm adding my file to the customer files section
under Sidewall grill.
Hope this helps.
/Hakan
"jmcfaddn" <Is
wrote in message
complicated. Trying to stretch or modify the existing grille elements turns
out to be a very difficult task. Has anyone modified one
successfully?
"jmcfaddn" <Is
wrote in message
successfully?
"Hakan Wikemar" <
href="mailto:Hakan.Wikemar@autodesk.com">Hakan.Wikemar@autodesk.com>
wrote in message
href="news:F3EA12D04DCF298267E4BDCB16AD2BD2@in.WebX.maYIadrTaRb">news:F3EA12D04DCF298267E4BDCB16A......
I'm sorry I just realized that you can't explode
non-uniform blocks and that blocks in blocks doesn't seem to work well with
The tools in Content Builder. I'll look into this matter
further.
/Hakan
skrev i meddelandet
href="news:9F259AF0752A83AC30BF6726708641D5@in.WebX.maYIadrTaRb">news:9F259AF0752A83AC30BF67267......
create blocks that are equivalent to a 1x1 Sidewall grill (inserted a
10*6 grill with different scales in x y and z), try and use this one in your
content drawing (just copy the blocks I placed in 0,0 to your dwg) and
then the procedure to create more grills should be as
follows:
desired mesurements in the scale option (for a 13x5 grill scale x=13
Y=1 Z=5)
block and move the horizontal grill
1" from the bottom and array 4 copies with 1" dist uppwards, do the
same thing with the verical one but with 0.75 dist and additional
times.
"13x5.....model"
before exploding the blocks.
section under Sidewall grill.
Hope this helps.
/Hakan
"jmcfaddn" <Is
wrote in message
an existing one to modify, it's made up of 40 different parts, very
turns out to be a very difficult task. Has anyone modified one
successfully?
"Slawomir Popiel" <
href="mailto:slawomir@ptd.net">slawomir@ptd.net> wrote in message
href="news:ED8FFCFED2532770B83CB301BF580199@in.WebX.maYIadrTaRb">news:ED8FFCFED2532770B83CB301BF5......
I think your best bet is to make it a parametric
part, instead. At leat that's what I did.
A plate 0.125" thick with square hole through it.
Dimensions of the hole change, the solid "ring" is constant, about 1.25". No
blades, no nothing.
Looks ugly, but I dont care. I need a part which
will insert where needed and I can tag it and schedule it.
sp
"jmcfaddn" <Is
wrote in message
successfully?
