how to convert excel files inserted in Autocad to Autocad entities? without having to open them in excel and exporting again to Autocad?
Thanks for your help...
AutoCAD and AutoCAD MEP cannot do this without help from 3rd party software. There are a few of them out there that will take an excel spreadsheet and import into autocad as an autocad table.
Here is one i found real quick. http://www.cadig.com/products/
Have you tried using the datalink command? After linking the excel spreadsheet you can insert the table using the table command and under insert options select from a data link. Use the dropdown to select the data link you created.
