AutoCAD MEP General Discussion
Active Contributor
dbillion
Message 1 of 4 (233 Views)
Accepted Solution
How do you find an MvPart in a drawing by "handle"?
233 Views, 3 Replies
04-30-2012 01:26 PM
Greetings,
I'm working in AutoCAD MEP 2011.
When running a clash detection of a 6-story building in Navisworks (each floor is a separate construct file), I can select an MvPart in the view and get that element's handle (unique identifier).  How can I find that particular part in the construct file, by searching for its handle?
Is there a lsp routine out there that allows the user to enter a MvPart's handle, and have the program zoom to that part?
Many thanks,
Dave
Valued Contributor
jcampbell
Message 2 of 4 (223 Views)
Re: How do you find an MvPart in a drawing by "handle"?
05-01-2012 06:02 AM in reply to: dbillion
Dave,
Try the below
code:
(defun C:HANDLE ( / handle ent )
(setq handle (getstring "\nEnter handle to search for: "))
(setq ent (handent handle))
(if ent
(progn ;line added
(sssetfirst nil (ssadd ent))
(command "_zoom" "_Object" ent)
;Else
(ALERT "The handle you entered does not exist in this drawing!")
(princ)
(defun OwnerName (handle)
  (cdr (assoc 2 (entget (cdr (assoc 330 (entget (handent handle)))))))
Active Contributor
dbillion
Message 3 of 4 (220 Views)
05-01-2012 06:30 AM in reply to: jcampbell
Works!  Just what I was looking for.  Thanks.
Valued Contributor
jcampbell
Message 4 of 4 (218 Views)
05-01-2012 06:48 AM in reply to: dbillion
Welcome.  You may want to mark my post as the solution.
Announcements
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
