Rick -
If you don't want to keep switching the catalogs, you can create a new
autocad profile that will do it for you. Go to the Options, Profiles tab.
Select Building Systems 3. Select the Add to the List (which means in ADT
speak: create a copy of the selected profile). Name the new profile
Building Systems 3 Metric. Make sure it is your current profile, then go to
the Building Systems Catalogs tab and select the metric catalogs. Now,
switch profiles to Building Systems 3 and make sure the catalogs are set to
imperial version. Now, if you need all the imperial catalogs, change the
profile to Building Systems 3 and if you need metric then change the profile
to Building Systems 3 Metric.
I hope this helps.
"jason martin [Autodesk]" wrote in message
news:E3AE1AD58442096606198DE0DF8A804D@in.WebX.maYIadrTaRb...
> Hi Rick -
> The setting that I "think" you changed in options only controls some of
the
> content. You'll need to modify your catalogs to also point to metric
> content.
> To do this launch building systems, and go into the options dialog. Scroll
> way over to the right and you should see a tab that says Building Systems
> Catalogs. There you will need to change the catalog path for each of the
> Catalogs. By default all of the catalogs are set to Imperial. If you
browse
> "up" a folder in each of them you should be able to select US Metric.
> hth
> jason martin
> Autodesk
> "rfeineis" wrote in message
> news:f136987.-1@WebX.maYIadrTaRb...
> > Depending on different projects we have a need to use both imperial and
> metric content for ABS 3.
> > During the installation of ABS3 you are prompted by default to install
> imperial content. I changed this setting and installed both imperial and
> metric content. When I launched ABS 3 it defaulted to imperial content. I
> then changed this to metric through the options dialog box.
> > When I make the change to metric I still can only insert imperial
content.
> What am I missing here?
> > Thanks!
> > Rick
