I made the lisp routine below a few years ago to draw a polyline with four points then fillet all the corners of the polyline.
It has always worked in AutoCAD 2008 and earlier versions, but I am getting errors now that I want to use it in AutoCAD MEP 2009.
It isn’t recognizing the “fillet” , “previous”, and “last” commands that AutoCAD 2008 was able to recognize.
It draws the polyline ok but fails once it gets to the fillet command...
Does anybody know what changes I need to make to this lisp routine to make it work in AutoCAD MEP 2009?
Here is the lisp routine:
(defun C:ppp () (command "pline" pause pause pause pause cr "fillet" "p" "l"))
Here is what is coming up on the command line...
Command: ppp
pline
Specify start point:
Current line-width is 0'-0"
Specify next point or [Arc/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
Command: fillet Unknown command "FILLET". Press F1 for help.
Command: previous Unknown command "PREVIOUS". Press F1 for help.
Command: last Unknown command "LAST". Press F1 for help.
Command: nil
