I'm trying to create a Home Run Schedule. So far I've added a manual property to the WireObjects Data Set named HomeRunLabel, then on the Home Run itself, I add text "HR-A" for example (no quotes).
The schedule I'm trying to create will contain the HomeRunLabel, Panel, Circuit, and Size Properties. However, with an out-of-the-box installation, I select "ALL" in my drawing and I see a line for every wire, regardless of it's a home run or not.
Does anyone have any ideas on how to filter these out? I'm thinking it's a formula column, but I can't seem to get it to work. The closest I can get is to add a Quantity Column, Total it, and hide it. That at least "sums" all of the other wires into a single line. I still see a row of ?s though.
Thanks in advance.
