Hi Rob -
I'm not sure why the help menu wouldn't be showing the building systems
help, unless you've reloaded the ADT menu? Anyway, as an alternate method
of getting to help you should be able to navigate to (assuming default
installation) c:\Program Files\Autodesk Building Systems 3\bsmep3.chm.
If you are getting the ADT help menu rather than the building systems help
menu, you should be able to type Menuload at the command prompt, then click
the Menu Bar tab. In Menu Group select BSCOMMON3, then in the Menu list
select Help, in the Menu Bar list select the last entry in the list and
click the Insert>> button.
hth
jason martin
"Rob Ward" wrote in message
news:051F19E459B52FDF528F58FF7A106E42@in.WebX.maYIadrTaRb...
> Aside from crashing a lot I have now lost my help menu. It does not open
> when I type "help" or when I try to use the menu up top. I have ABS3
> installed on my desktop and I am running windows 98. Can anyone give me a
> ny ideas.
