AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
GROOVED PIPE CONNECTIONS
0 REPLIES 0
Message 1 of 1
mjmpe
465 Views, 0 Replies
I am drwg in MEP 2013. and drwg with grooved pipe I find it hard to designate where exactly the finally connection is on the fittings, when you look in close there are two little dots on the fittings and when you hover over it gives you two pipe curve connections, How do you know exactly where the final connection should be/ some of my measures are coming out 1/8" difference, I know its not much but would like it to be accurate. also when you draw the pipe between two fittings it doesn't look like the pipe is into the grooved coupling/ fitting how come?
thanks
0 REPLIES 0
”Boost
