AutoCAD MEP General Discussion
New Member
cad01
Message 1 of 2 (771 Views)
Generating an Isometric drawing from a 3-D drawing
771 Views, 1 Replies
04-24-2012 01:16 PM
I am using AutoCAD MEP 2012.  Is there a command that will generate an Isometric one line drawing from an already created 3-Dimensional drawing?
*Expert Elite*
Keith.Brown
Message 2 of 2 (768 Views)
Re: Generating an Isometric drawing from a 3-D drawing
04-24-2012 01:27 PM in reply to: cad01
There is not a command to generate a isometric drawing from a 3D model.  But what you can do is put your model into an isometric view and change your display representation to a display that forces pipe to display as single line.
It does take some manipulation of the display system in order to make it work but a "reasonable" isometric drawing can be created.  I like to create container drawings that xref in my model so I can use xclip in order to logically break my isometric drawings up.  That way I do not have my complete model as one isometric but several isometric drawings that represent the complete design.  The project management system is of benefit when using this method.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Post to the Community
New Post
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
