AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
FONT CHANGES
3 REPLIES 3
494 Views, 3 Replies
FONT CHANGES
May I know why font changes each time I copy from the paper space in an old sheet to a new one?
3 REPLIES 3
s.lawrence
Check the style of text you are cutting and pasting. Type ST at the command line.
You'll probably find that the style you are copying exists in the new drawing and uses a differnt font.
in reply to: s.lawrence
Thank you for responding. Does it then mean that if I'm copying an existing font it will be overridden? I need more clarifications please. Thanks.
s.lawrence
If you type 'ST' at the command line and press enter, it will bring up the 'Text Style manager box. In the left window will be a list of the existing styles in your drawing. With each of these styles will be associated a font name, a height, width factor etc. If you copy text of this style (for example, style 'Romans') into a drawing which also contains the same style name ('Romans'),when you paste the text will inherit the style in the new drawing.
There may be a couple of other reasons this may be happening, but I would imagine this is the correct one..
Stu
”Boost
