AutoCAD MEP General Discussion
New Member
Folatwins
Message 1 of 4 (278 Views)
FONT CHANGES
278 Views, 3 Replies
03-16-2013 06:45 AM
May I know why font changes each time I copy from the paper space in an old sheet to a new one?
Valued Contributor
s.lawrence
Message 2 of 4 (253 Views)
Re: FONT CHANGES
03-18-2013 12:44 AM in reply to: Folatwins
Check the style of text you are cutting and pasting. Type ST at the command line.
You'll probably find that the style you are copying exists in the new drawing and uses a differnt font.
New Member
Folatwins
Message 3 of 4 (244 Views)
Re: FONT CHANGES
03-18-2013 08:17 AM in reply to: s.lawrence
Thank you for responding. Does it then mean that if I'm copying an existing font it will be overridden? I need more clarifications please. Thanks.
Valued Contributor
s.lawrence
Message 4 of 4 (242 Views)
Re: FONT CHANGES
03-18-2013 08:24 AM in reply to: Folatwins
If you type 'ST' at the command line and press enter, it will bring up the 'Text Style manager box. In the left window will be a list of the existing styles in your drawing. With each of these styles will be associated a font name, a height, width factor etc. If you copy text of this style (for example, style 'Romans') into a drawing which also contains the same style name ('Romans'),when you paste the text will inherit the style in the new drawing.
There may be a couple of other reasons this may be happening, but I would imagine this is the correct one..
Stu
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
