AutoCAD MEP General Discussion
Active Member
Watershape2
Message 11 of 18 (5,279 Views)
Re: Flattening 3D to 2D
02-23-2011 07:26 PM in reply to: bytown
Accessed via the right click menu.
(Edit: Wooops you're on a mac, hmmm I'm not sure how that works with macs)
(Edit2: Entering properties in the command line should do it)
Active Member
jdd285
Message 12 of 18 (5,275 Views)
02-23-2011 08:14 PM in reply to: Watershape2
ok so this is what i have done. i found a friend who has autcad 2008 .. opened the file and command: FLATTEN .... it worked for one file but not the other... I not sure why. any suggestions or anyone willing to try it out? also i would like to find out how to fix this problem without depending on older versions...
Thanks for all the help.
 lets keep trying
Distinguished Contributor
Schmit01
Message 13 of 18 (5,268 Views)
02-23-2011 11:12 PM in reply to: jdd285
Make sure that the contors you trying to flatten arent locked under your layer manager. I found that to be the case with the file you posted.
Active Member
jdd285
Message 14 of 18 (5,266 Views)
02-23-2011 11:50 PM in reply to: Schmit01
your correct. the layers were locked however, after unlocking them still could not get it to work.
New Member
raajmath
Message 15 of 18 (4,783 Views)
08-10-2011 11:23 PM in reply to: jdd285
hey your file need to be unlocked then you can do the flatten
ok
Valued Mentor
jeff
Message 16 of 18 (4,778 Views)
08-11-2011 01:22 AM in reply to: raajmath
Valued Contributor
%4seasons%
Message 17 of 18 (4,772 Views)
08-11-2011 07:04 AM in reply to: jeff
try exploding it while you are on the top view.
Valued Contributor
%4seasons%
Message 18 of 18 (4,752 Views)
08-12-2011 01:50 AM in reply to: %4seasons%
what i suggested was only for MEP  3D objects. i saw your uploaded drawing and i would suggest you to make the start/end z elevation equal. i have tried it and it works (see attached). you have to spend some of your time since you cannot select all in one go so you have to select by group or each line.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
