AutoCAD MEP General Discussion
Valued Contributor
mjmpe
Message 1 of 5 (438 Views)
fixing the take-out of fittings
438 Views, 4 Replies
04-11-2013 07:53 AM
Can someone walk me thru the process of changing the fittings to the appropiate take-outs. I am drwg 4" buttweld and I have 90's in there, that should be long radius elbows. The take-out should be 6" and it is measureing 4-01/4". I went into pipe preferences and all it gives me is generic elbows to choose from. how/where do I find LR elbows? or how do I change the take-out of the generic elbow.
thanks
Valued Mentor
kwizats_haderack
Message 2 of 5 (419 Views)
Re : fixing the take-out of fittings
04-13-2013 02:41 AM in reply to: mjmpe
could you send me a example and i check.
Bien cordialement / Best regards
Erwan ( FRENCH AUTOCAD M.E.P CAD/BIM MANAGER )
Keith.Brown
Message 3 of 5 (383 Views)
Re: fixing the take-out of fittings
04-22-2013 03:41 PM in reply to: mjmpe
Please make sure that you are looking in the correct catalog.  There are Butt Welded fittings under the General Pipe (US Imperial) catalog but these are all GENERIC fittings.  Under the Steel Pipe catalog there is a section for Butt Weld fittings with the correct dimensions.  The 4" Butt Weld LR Elbow has a 6" takeout.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Keith.Brown
Message 4 of 5 (381 Views)
04-22-2013 03:48 PM in reply to: Keith.Brown
Pictures of the two very different elbows.
Valued Contributor
mjmpe
Message 5 of 5 (366 Views)
04-23-2013 05:00 AM in reply to: mjmpe
Keith,
 I think I am spinning my wheels here. I looked exactly where you told me to  for the LR elbows, my catalog does not even give a a buttweld choice. I went into General pipe (US Imperial) I do not have an option to choose Buttweld. All it gives me is Flanged, Glued, and Threaded. Is this where the problem is? And when I go into my style manager/ parts routing preference when I scroll down all my imperial parts are grayed out & I cannot pick them.
GENERAL PIPE (IMPERIAL)
HDPE PIPE (IMPERIAL)
COPPER PIPE (IMPERIAL)
PLASTIC PIPE (IMPERIAL)
CAST IRON (IMPERIAL)
DUCTILE IRON (IMPERIAL)
All these are grayed out and I cannot choose them. I think this is where the problem is, not sure though.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
