AutoCAD MEP General Discussion
Active Contributor
Milos84
Message 1 of 3 (335 Views)
Fixation units - flow diagram
335 Views, 2 Replies
10-05-2012 02:29 AM
is there any possiblity and if yes how to change Fixation unit - flow diagram for plumbing sizing?
I would like to define the different diagram than the standard but i just cannot find it.
any support would be excelent and i would be gratefull if somebody could support in this matter.
Thank you
Active Contributor
Milos84
Message 2 of 3 (333 Views)
Re: Fixation units - flow diagram
10-05-2012 02:32 AM in reply to: Milos84
Sorry - Fixture unit diagramm
Keith.Brown
Message 3 of 3 (324 Views)
10-05-2012 09:33 AM in reply to: Milos84
Go into the style manager found on the manage tab of the ribbon.  Once there expand Plumbing Objects and then Fixture Unit Table Definitions.  Right Click on the standard table and copy/paste a new definition.  Rename to a name consistant with your standards and then modify your new table.  Also under Plumbing Objects you will find the Sanitary and Supply Sizing Tables that will also need to be duplicated and modified to your standards.
Hope this helps.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
