To narrow down the problem, what happens if you work with the property
palette closed. Of course, it is not possible to do a lot of work this way
but I am just trying to understand under what specific scenarios, if any,
does this problem occur.
Jitender
wrote in message news:4924612@discussion.autodesk.com...
1. It does do it a lot when i open a new drawing when I have a couple of
them open. it even happened when I only had one drawing open. I also can be
trying to plot, change views or running a simple command. We have been
trying to find a connection between the error but no luck.
2. I have the property palette open when I work. I have 2 monitors running
with ABS06 and it is in the other monitor.
The only thing I can think of is that we saved it in ABS05 and running on an
05 template in 06. Thanks for any help.
