You are not able to do it as documented. I asked the question and received
the following answer:
To explain, the "Tool Palettes" tab in the customize dialog box is available
only with AutoCAD 2004.
With ADT 2004 and ABS 2004 this option is not available since both these
software's use "Content Browser" to store and distribute tool palette
contents.
I'm copying below a documentation explaining the procedure to export Tool
Palettes in ADT 2004 (applicable to ABS 2004 as well):
In Architectural Desktop 2004 the Autocad 2004 functionality to Export the
Tool Palettes with a Right Click, has been disabled due to the
interoperability with the commands and the Design Center Content.
Administrator Tool Palettes:
Customize the Tool Palettes on system A
Open the Aec Content Browser
Create a new Catalog and save it to a network location
Select the Tool Palette Tabs you want to export and drag them slowly to the
Aec Content Browser with the left mouse button pressed down
Open the Aec Content Browser on a client system B and browse to the network
location
Insert the Tool Palettes per drag and drop into your Palettes
The inserted palettes are applied with a refresh option, that means that
thes Tool palettes are updated every time you start Architectural Desktop .
This functionality can be disabled in the Palette Options
The administrator can set additional Open/Write options to this network
location, to prevent that the common used Tool Palettes are modified by
users without appropriate user rights.
Please reset the path to the Design Center Content the Architectural
Desktop Options, if they are placed also on a network location. The content
folder structure should be used in the default way to ensure the full
functionality of all DC tools, like tags.
Export Tool Palettes from System A to System B
Customize the Tool Palettes on System A
Copy all files in the folder C:\Documents and Settings\username\\Application
Data\Autodesk\Autodesk Architectural Desktop
2004\R16.0\enu\Support\WorkspaceCatalog
Paste the *.atc files to the same folder on System B
This Tool Palettes are transferred once without a refresh update
functionality
If the Tool Palettes are changes on System A, you will have different
Versions of the Tool Palettes on System A and System B
However installing the "Tool Palette" extension with ADT 2004 and ABS 2004
brings in the "Tool Palette" tab in the customize dialog box. And as
observed by you this does not have the rename, delete, export, import
buttons. This is as designed
"Bill Brookman" wrote in message
news:4B8F3112F69469763B35E372C82CBACC@in.WebX.maYIadrTaRb...
> I've installed the tool palette extension. The help file indicates I can
> export the palette by right clicking and using the customize screen. Is
> this an error in the documentation? I would like to set up custom
palettes
> and use them both at work and at home. Is this possible?
> Thanks for any help.
> bb
