Please, jarod@indra.com
Thanks...
"Michael Sonnier" wrote in message
news:FB1C7D16CB227E9F6B8D5AF9D24D00B7@in.WebX.maYIadrTaRb...
> Did you want me to email you a copy of my ABS 3 template?
> Michael Sonnier
> news:5945AD5134B9D5671B3E8328AD994CDD@in.WebX.maYIadrTaRb...
> > I actually am using my old template from ABS 3. (customized)
> > I did have a chance to look at the ABS 4 templates (Aecb Electrical
Model
> > (Imperial - ctb) 4.dwt, Aecb Building Model (Imperial - ctb) 4.dwt) and
> > neither one seemed to work. hummm. Interesting.
> > Maybe someone from AutoDesk can look at this? Jason Martin maybe?
> > Michael Sonnier
> > "Jarod J. Schultz" wrote in message
> > news:BAA09EFA1322E29267AF8E3830C6D486@in.WebX.maYIadrTaRb...
> > > Thanks for looking. I'm using the default Aecb Electrical Model
> > (Imperial -
> > > ctb) 4.dwt out of the box and not getting the devices to show on the
> > > elevation. Which template did you use to have them show on the
> elevation?
> > > Thanks, Jarod
> > > news:A9DA2350852A04EFE474C7F2AE6F35F7@in.WebX.maYIadrTaRb...
> > > > I took a quick look at your drawing, and you are right your devices
> > aren't
> > > > showing up correctly on an elevation. I think it might be something
in
> > > your
> > > > display reps. (unfortunately I don't have the time today to look
> further
> > > > into it). I typically don't do electrical elevations but I tested
> > > electrical
> > > > template and it work fine.(Receptacle, switches, lights, data,
etc..)
> > > > Michael Sonnier
> > > > news:AEE30F25989CA7BBDE2C1F7876C1A3D3@in.WebX.maYIadrTaRb...
> > > > > The subject is "Elevation with Receptacles " in
> > > > > autodesk.autocad.customer-files
> > > > > news:FD08E656C711459117A60EBFA9676CEC@in.WebX.maYIadrTaRb...
> > > > > > Is there no way of showing electrical devices (AecbDeviceAdd) in
> > > > elevation
> > > > > > using the AecBldgElevationLineAdd command? I have a drawing
loaded
> > at
> > > > > > autodesk.autocad.customer-files under the subject of "Elevation
of
> > > > > > Electrical Devices" to show the issue. I have to show where the
> > > > electrical
> > > > > > devices need to go in elevation for a Hospital. I already have
it
> > > drawn
> > > > in
> > > > > > plan and I want Building Systems to draw the elevations for me.
> > There
> > > > has
> > > > > to
> > > > > > be a way to do this?!?!
> > > > > > Thanks, Jarod
