style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Toma1379" <Is
href="mailto:tarmbruster@aegroup.org">tarmbruster@aegroup.org> wrote in
message
href="news:f19a1f3.-1@WebX.maYIadrTaRb">news:f19a1f3.-1@WebX.maYIadrTaRb...
it possible to create a wire style with an "E" in it for emergency wiring,
similar to and abbreviation like CW in a pipe
Tom A.
"Toma1379" <Is
message
Tom A.
"Hakan Wikemar [Autodesk]" <
href="mailto:hakan.wikemar@autodesk.com">hakan.wikemar@autodesk.com>
wrote in message
href="news:DA53B945DFF482254FD3B20109296193@in.WebX.maYIadrTaRb">news:DA53B945DFF482254FD3B201092......
Hi Toma!
If I understand you correctly you would like to
change your wire style to automatically label your wires with an E for an
emergency wirestyle. Unfortunately you can't use automatic labeling with wires
:(. You can label your wires by hand as usual.
I tried a "strange" workaround if this would help
you in any way... First I created a block of an E (text) with an offset
insertionpoint + one block looking like the conductor/neutral/ground
ticks, then I Used the tick marks annotation in the wirestyle and
assigned no block to the Conductor, and my custom blocks; E to Neutral
and ticks to Ground, set angle to zero and fiddled a bit with the distance.
Now I got a style which always inserts E + ticks. The limitations are
that the E will always go on the same layer as the ticks and wire + the E
doesn't mask the wire.
hth
/Hakan Wikemar
"Toma1379" <Is
in message
Tom A.
