AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
electrical system definitions
1 REPLY 1
181 Views, 1 Reply
Hi Peter -
That's because there is something on this system. If there is something on
the system these controls are disabled "by design" as changing them could
break any connections that exist for items on the system. If you want to
change these, you have to first remove everything from the system.
Would you mind also specifying a "name" in your newsreader. If the names are
blank it can cause "issues" with the http version and the search engine.
jason martin
wrote in message
news:88A4393B6EDD15059D27C7C98B7E9A8B@in.WebX.maYIadrTaRb...
> On the design Rules tab for the electrical system definitions of the 120V
> Lighting Devices (wall,ceiling and Power devices) the cells for the System
> group and System Type are greyed out. In other System definitions these
> areas are editable. Is there a setting controlling this?
1 REPLY 1
Thanks for the two answers Jason.
I fixed my from name issue. It seeemed that not setting
discussion.autodesk.com as my default account was the problem.
"jason martin [Autodesk]" wrote in message
news:7B6DFF7FAFB90F2A2312D6706D37BCD5@in.WebX.maYIadrTaRb...
> Hi Peter -
are
> jason martin
> Autodesk
> wrote in message
120V
System
”Boost
