I am drawing a blank....
.... what is the command to edit the geometry of the display rep if you can find a better solution?
The command I believe adds another component to the display rep being edited...
Solved by mdhutchinson. Go to Solution.
Solved by Keith.Brown. Go to Solution.
Change up the title... maybe this will turn up the command I need.
What I want will allow me to edit the actual geometry inplace.... the action, I believe adds a special DisplayComponent in the current DisplayRep being used.
Sorry, I missed this somehow.
Anyway, i believe that the command you are looking for is OBJECTGRAPHICSEDIT . For the record it is available on the ribbon when you select an object. At least it is there when i select a duct fitting.
HTH
Thanks Keith!
just tried it... phooyey! it doesn't work on structural members.
