As a note to all:
If you are going to try and use content builder, be sure the SDI variable is
set to 0. The parametric portion of content builder needs to create a new
drawing to work correctly, so it will not work if SDI is set to 1.
jason martin
"Buster1379"
wrote in message
news:f13d7b4.-1@WebX.maYIadrTaRb...
> Still need some help on creating a variable length duct transition. I
downloaded the file as directed previously, but when I create a new
transition (test transition) as described in the video and select OK it
kicks me out of the content builder and the new transition part is not
created. Also if I try to modify one of the existing transitions it also
kick me out of the content builder.
> Please Help
> Tom
