AutoCAD MEP General Discussion
Member
luke3057
Message 1 of 2 (676 Views)
Duct Lining & Insulation
676 Views, 1 Replies
03-06-2012 01:50 PM
Hello ...
I am new to MEP 2012.  I am looking to find out how I change the color and line type for the duct lining and insulation.
Keith.Brown
Message 2 of 2 (675 Views)
Re: Duct Lining & Insulation
03-06-2012 01:56 PM in reply to: luke3057
The quickest and easist method is to right click on a piece of ductwork and select edit object display.  From there click on the bolded display representation and it will open up the display property dialog.  Here you can turn off the lining, edit the color, the layer, or the linetype.  To edit the layer, the layer must already exist in the drawing.   Editing it in this manner will also change the lining display for duct fittings and flex duct.  If you need it to change colors in more than one display representation, you will need to make the change in EACH display representation.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
