I agree, but to be fair, how often is it likely to be a problem? Personally, I would only resort to short runs of tall skinny duct sizes where nothing else would work. Just remember not to try and label the height of that segment, except perhaps with a bit of dumb text. Vertical space is generally far more limited than horizontal space in voids, plantrooms etc.
You'll always want the next version
A bigger problem for me was Bottom of Duct labels that INCLUDED INSULATION in their calculations! What is the point of that? Duct is generally installed first and then insulated. Luckily, you can edit the expression in the Style Manager and delete the 'insulation thickness' variable.
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
