i have a problem with the Autocad MEP 2015. Everytime i try to add a duct with + symbol on duct i wait between 4-6 seconds to have a duct, the same thing at the end of the duct placing.
Someone have the same problem?
I've had that happen with files that were upgraded from an earlier release - but I did find that a quick copy and paste to a new drawing started from a template fixed it. You might also want to show disconnects to see if the system got broken somewhere - I had a bunch along a well-formed system from an earlier release. After fixing it. the file worked fine.
thanks - db
David A. Butts
Engineering Technology Manager - Gannett Fleming
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
Good tip Dave. I have had this problem in the past and was at a loss of what to do. Fortunately for me the file was very small and i could just restart it.
If the slow duct add only occurs when using a visual style other than 2D Wireframe try setting DISPSILH to 0.
JMV
I tried all, but change nothing...I see that happens when i have a lot of detail in 2d in the drawing. For example a 2d plan to reference, if i unload work a little better.
At this point, it's most likely the model has become corrupted. While the Audit command may help clean it up, do you have a backup file from a previous day that you can go back to?
If you do, then take that version, and use the copy/paste method to place the existing content into a new drawing started from your templates. Make sure you don't have any reference files included in the copy/paste - you'll need to re-attach those separately. If you want to post the files here, I'll check them out.
thanks - db
David A. Butts
