AutoCAD MEP General Discussion
Valued Contributor
anovelli
Message 1 of 4 (377 Views)
Do MEP Objects Respect the Cut Plane?
377 Views, 3 Replies
01-18-2008 06:22 PM
This is hopefully a very simple question. I think I know the answer. Just wanted fellow AUGI Users take on this. Do the MEP Objects (Pipe, Fittings, MV Parts,etc) respect the Cut Plane Feature? So far I think the answer is NO since I have fiddled with it and was NOT able to get ANY MEP Objects to display properly when I changed the CUT PLANE values. The Architecture Objects DO respect the cut plane and seem to work. But the MEP Objects do NOT cooperate. Any thoughts or conformation on this? Please let me know. I am using Architecture and MEP 2008. Thanks!
Employee
martin.schmid
Message 2 of 4 (377 Views)
Re: Do MEP Objects Respect the Cut Plane?
01-20-2008 03:23 PM in reply to: anovelli
The answer is yes and no.
In general, the MEP objects do NOT respect the cut plane, however, new in 2008 is the ability for Duct domain componets (ducts, flex ducts, duct fittings, custom duct fittings) to 'display by elevation'. (Options > MEP Display Control > Enable Display by Elevation).
Refer to the documentation for more information.
HTH,
MS
Martin Schmid, P.E.
Product Manager - Revit MEP
Architecture, Engineering, and Construction
Valued Contributor
anovelli
Message 3 of 4 (377 Views)
01-21-2008 07:23 AM in reply to: anovelli
Thanks for response. Are there any plans to add this capability into the next Version of MEP 2009? It would make cutting the 2D Plans MUCH easier. Please let me know.
Valued Contributor
SLDBrown
Message 4 of 4 (252 Views)
09-18-2012 12:14 PM in reply to: anovelli
I know I'm late to this party but my issue is partialy relevant. I am using MEP 2012. I established my Cut Plane variables but not all my piping shows.The pipes are from the same pipe system but some show and some don't. the Cut Plane isn't showing me any respect. Any thoughts?
Steve
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
