AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Display Manager - Section centrelines
7 REPLIES 7
Message 1 of 8
alatier
684 Views, 7 Replies
I Have a problem with displaying centrelines in sections
I hav a set that acutually does it, but I cant see which box to tick
I have a set that i am happy with, except the cenrelines arnt shown
Can somebody tell me where pipe centreline visability is controlled from?
Pete
7 REPLIES 7
Message 2 of 8
VitalyF
in reply to: alatier
Use MEP default templates or modify Display setting from the context menu pipes
Vitaly
Message 3 of 8
alatier
in reply to: VitalyF
It is eactly what i need to do, but when I look at the options, I am not seeing centreline appearing
The attached shot is of a section that shows centrelines, I have another section (on the same file),cut with a different style which does not have centrelines, but shows the same options on display properties
I am missing somthing
I would really like to be able to conrtol this
Pete
Message 4 of 8
info
Hi VitalyF,
that really looks great, but I can't figure it out.
I have the same problem.
I have used the default template
I have enabled the center line (it was already enabled) and
I have regenerated the section...
nothing happens, the section is still without a center line...bad luck
Joeycool
Joeycool
MEP 2013, 2014, 2015, 2016, 2017 (DACH)
Message 5 of 8
VitalyF
in reply to: info
Hi
alatier
info
Send me an example acadvaf@yandex.ru
Message 6 of 8
VitalyF
To create a section to complete a number of rules:
1. Use the default MEP template, or template based on it
2. Use only MEP objects and/or 3DSolid and blocks or xrefs from them
3. For MEP objectss use options FACETDEV = 1
4. For 3dSolids see videoclip
Vitaly
Message 7 of 8
info
Hi Vitaly and alatelier,
I think I've got it.
You need to select in the section window the Style "MEP-Standard-hide", you must not select MEP-Standard (ref #1).
Fpr Display Sets (ref #2) you have to select either "Section" or "Section Hide". One of it should be preselected, which one you chosse, doesen't matter, they're both the same (in the german template).
After refreshing you have the pipe Lines and also the center line in the section, but only displayed in hidden Style.
Joeycool
Message 8 of 8
VitalyF
in reply to: info
Hi info,
Sorry I did not answer for a long time!
Your example works fine with "AutoCAD MEP 2014 - Deutsch (German)" templates.
I did it for your example, see above example step by step  (ref #1, 2)
Vitaly
”Boost
